Natedog
Replaced my egr block off plate gasket today and it runs better, but the timing continues to jump around when the spout plug is in.
EDIT: also changed my ACT sensor sense I had a nib sitting around. The old one looked original and was all covered in black tar like goo. Cleaned the threads with brake cleaner before I put the new one in. Also made sure that all the ports off the upper intake were not plugged up by poking the brake cleaner spray tube through from the outside after unplugging the vacuum lines. Gave em all a little shot of cleaner just to be sure. All seamed to be clear but grungy dirty in the upper intake.
Exhaust pipe smells slightly rich imo when it's idling in neutral and at operating temp.....
