im just posting the topic as to get some solid clarity here.
if you want "clarity" posting a question that has a varying answer from state-to-state, in a forum with members across the globe won't get you that. go to a local state safety inspection station and ask, here in utah we have a hotline people can call.
			the point of this post.  to try to get some real evidence, like links to a gov website
so here you go, here are some "links to a gov website"
that won't help you anyway because vehicle safety laws vary from state-to-state
but you can just google your state's safety handbook as well
here's an example:
http://publicsafety.utah.gov/safetyinspections/safetyinspection.html
it can be seen on page 43 of this link:
http://publicsafety.utah.gov/safetyinspections/docs/X2009-2010 SI PLT ManuaL.pdf
but ultimately it says that only the "xenon" style hid lights are allowed, but they still must only project white light, still must be aimed correctly, and still must be d.o.t. approved (d.ot approvals only cover the headlight unit in its original "as approved" state)
SECTION 7 - LIGHTING
• Lenses that are patched, taped or covered with a temporary substance and lenses that have been equipped with any tinted covers MUST BE REJECTED.
• Lights must conform to manufacturer's specifications, Federal Motor Vehicle Safety Standards (FMVSS) and Utah State Laws.
• In 1996 the use of a clear cover for headlamps was approved for marketing in Utah (See NOTE in Headlamps).
Xenon bulbs are USDOT approved.
A. HEADLAMPS
1. Check headlamp for proper mounting.
a. REJECT when:
1) Mounting brackets are loose, missing or damaged in any way so that headlamp cannot be properly and securely mounted.
2. Check headlamp for proper aim and lighting.
a. REJECT when:
1) Headlamps are not aimed to specifications.
2) Headlamps fail to light properly.
3)
Headlamps project other than white light.
4)
Headlamp is not marked USDOT approved
NOTE: See Headlight Aiming Reference.
3. Check headlamps for holes, breakage and non-factory colored covers or nontransparent covers.
a. ADVISE when:
1) Headlamp has holes in headlight lens. (These holes may be sealed with silicone).
b. REJECT when:
1) Headlamp coverings, not authorized by the department, are placed on or in front of any headlamp. Factory installed lights/covers are faded or painted to the point assembly will not comply with state code for visibility at 1,000 feet. (U.C.A. 41-6a-1603)
2) Headlamp cover is broken or missing. PLT Safety Inspection Manual, Effective January 1, 2009 43
LIGHTING - Continued
*NOTE: Impact Headlight Savers Inc. manufactures a clear laminate product that can be attached to a headlight to cover holes or cracks and to help keep the headlight from breakage. The cover does not discolor with age and meets FMVSS standards. The cover is acceptable as a permanent repair and will pass inspection.
B. HEADLAMPS - HIGH AND LOW BEAMS
1. Check dimmer switch for proper functioning. Both high and low beams are required to function.
a. REJECT when:
1) Dimmer switch fails to work properly.
C. BACKUP LIGHTS / LICENSE PLATE LIGHT
1. Check the backup lights for proper functioning.
a. ADVISE when:
1) Backup lights or rear license plate lights are missing or fails to light.
b. REJECT when:
1) Backup lights remain illuminated when transmission is not in reverse.
D. HAZARD WARNING LAMPS
1. Check hazard warning lamps for proper functioning.
a. REJECT when:
1) Hazard warning lamps fail to function properly.
E. INTERIOR INDICATOR LAMPS
1. Check interior lamps for proper functioning.
a. REJECT when:
1) Turn signal indicators, high beam indicator, brake warning indicator or parking brake indicator fail to function.
PLT Safety Inspection Manual, Effective January 1, 2009 44
F. PARKING LAMPS
1. Check parking lamps for proper functioning.
a. REJECT when:
1) Parking lamps fail to function properly or display an unapproved color.
G. SIDE MARKER LAMPS (SIDE REFLEX REFLECTORS)
1. Check side marker lamps for proper functioning and color.
a. REJECT when:
1) Side marker lamps are not functioning properly.
2) Side marker lamps or side reflectors are incorrect color.
*NOTE: Side marker lamps must be yellow or amber on the front and red on the rear. (FMVSS 108)
H. AUXILIARY LIGHTING
1. Check auxiliary lamps for proper mounting and aiming. Auxiliary lights must be USDOT approved, mounted between 15" and 56" in height, have a separate switch to operate, and may ONLY be white, yellow or amber in color.
a. REJECT when:
1) Auxiliary lamps are improperly mounted, aimed and/or fail to direct light properly. (Auxiliary lights may not be aimed higher than the low beam headlight).
2) Auxiliary lamps are other than white, yellow or amber.
3) Auxiliary lamps are not USDOT approved.
I. TAIL LAMP ASSEMBLY
1. Check tail lamp assembly for proper lenses and required reflex reflectors.
a. REJECT when:
1) Rear lenses do not produce red light, are painted or are covered by any lens covers.
2) Lenses are missing required reflectors.
PLT Safety Inspection Manual, Effective January 1, 2009 45
*NOTE: A NHTSA interpretation indicates that aftermarket taillight covers create a non-compliance issue with FMVSS 108 (S5.1.3). Also, Utah Code 41-6a-1618 states that lighting devices may not be used if they “tend to change the original design or performance” of the original device.
2. Check lens covers for breakage.
a. REJECT when:
1) Tail lamp lenses are broken to the extent that any white light shows through broken area.
*NOTE: Lenses that are patched with another lens piece is an acceptable repair, so long as it is glued on and permanent. Tinted covers and temporary patches MUST BE REJECTED.
3. Check for the proper operation.
a. REJECT when:
1) Tail lamps fail to light properly.
4. Check for proper mounting.
a. REJECT when:
1) Lamps are not securely mounted.
5. Check for visibility.
a. REJECT when:
1) Lamps are not visible from a distance of 500 feet in normal light.
J. STOP LAMPS
1. Check stop lamps for proper color.
a. REJECT when:
1) Stop lamp lenses are not red in color, are painted or covered. (Blue dot taillights are illegal).
2. Check the stop lamps for breakage.
a. REJECT when:
1) Stop lamp lenses are broken to the extent that white light is visible to the rear.
NOTE: Lenses that are patched, taped, painted or covered with a temporary substance and lenses that have been equipped with any tinted covers MUST BE REJECTED.
PLT Safety Inspection Manual, Effective January 1, 2009 46
3. Check for the correct operation of stop lamps.
a. REJECT when:
1) Stop lamps do not operate or fail to light properly.
4. Check for proper stop lamp mounting.
a. REJECT when:
1) Stop lamps are not securely mounted.
5. Check the visibility of stop lamps.
a. REJECT when:
1) Stop lamps are not visible from a distance of 500 feet in normal light.
2) LED lights have less than 50% of diodes illuminated.
6. Check center high mounted stop lamps. They are required on passenger vehicles manufactured after September 1985. Trucks manufactured after September 1993 that have a shell installed are also required to have a center mounted stoplight on the rear of the shell in order to be in compliance with 49 CFR 571.108.
a. REJECT when:
1) Center high mounted stop lamp is not present or does not light.
2) If any after market tint has been applied over the center high mounted stop lamp.
3) LED lights have less than 50% of diodes illuminated.
*NOTE: Some passenger vans and SUV’s manufactured prior to 2003 may have center brake lights mounted under AS-3 privacy glass. These vehicles pass safety inspection as long as no aftermarket tint has been applied to the glass.
K. TURN SIGNAL OPERATION
1. Check the turn signals on all vehicles manufactured in 1956 and later.
a. ADVISE when:
1) One of the two bulbs fails to illuminate on a two bulb system.
b. REJECT when:
1) Vehicle is not equipped with proper signals.
2) Turn signals fail to function.
PLT Safety Inspection Manual, Effective January 1, 2009 47
2. Check switch for proper functioning.
a. ADVISE when:
1) Switch does not cancel automatically for 1956 and later vehicles.
b. REJECT when:
1) Turn signal lever needs to be held in the on position.
3. Check condition of lenses.
a. REJECT when:
1) Turn signal lenses are painted, broken or missing.
*NOTE: Lenses that are patched with another automotive lens piece is an acceptable repair, so long as it is glued on and permanent. Tinted covers and temporary patches MUST BE REJECTED.
a. REJECT when:
1) Turn signals are not securely mounted.
5. Check for proper color of lenses and bulbs.
a. REJECT when:
1) Turn signal colors are not red, yellow or amber in the rear or amber in the front.
2) Turn signal lenses or bulbs are painted.
6. Check for visibility of lenses.
a. REJECT when:
1) Turn signals are not visible from a distance of 100 feet in normal light.
*NOTE: Lamps must be located at the same level and as widely spaced laterally as is practical.
PLT Safety Inspection Manual, Effective January 1, 2009 48
L. LIGHTING-GENERAL REQUIREMENTS ON ALL VEHICLES
Equipment required at the time the vehicle was manufactured to meet FMVSS 108.
*NOTE: No light colors other than those described on the chart are allowed. Neon lights are not acceptable. Xenon headlight bulbs are acceptable.
LIGHT
LOCATION
HEIGHT
COLOR
NUMBER
Headlamp (not required on trailer)
Front
22"- 54"
White
2 or 4
Tail lamp
Rear
15" - 72"
Red
2 or more
Turn Signal Lamp (not required on truck-tractor if front turn signals are double-faced and visible from the rear)
Front (not less than 4" from low-beam headlamp-SAE J 588e) Rear
15" - 83" 15" - 83"
Amber Red or Amber
2 or more 2 or more
Hazard Lamp (same lamp as turn signal)
Front Rear
15" - 83" 15" - 83"
Amber Red or Amber
2 or more 2 or more
Stop Lamp
Rear
15" - 72"
Red
2 or more
License Plate Lamp
Rear, at license plate
White
1 or more
Side Marker Lamp (not required on truck-tractor)
Side near front Side near rear
15" minimum 15" minimum
Amber Red
1 each side 1 each side
Backup Lamp (not required on trailer)
Rear
White
1 or more
Rear Reflector
Rear
15" - 60"
Red
2 or more
Side Reflector (not required on truck-tractor)
15" - 60" 15" - 60"
Amber Red
Intermediate Side Lamp (if vehicle overall length is 30' or greater)
Side near center
15" minimum
Amber
1 each side
Intermediate Side Reflector (if vehicle overall length is 30' or greater)
Side near center
15" - 60"
Amber
1 each side
PLT Safety Inspection Manual, Effective January 1, 2009 49
In addition to the above chart, the following lights are required on all vehicles 80” wide or wider.
LIGHT
LOCATION
HEIGHT
COLOR
NUMBER
Parking Lamp (only if vehicle is less than 80" wide)
Front (not required on trailer)
15" - 72"
Amber or White
2 or more
Identification Lamp
Front, spaced 6"-12" on center (not required on trailer)
Rear (not required on truck-tractor)
As high as practical
Amber
Red
Clearance Lamp
Front, at widest point
Rear, at widest point (not required on truck-tractor)
Amber
Red
PLT Safety Inspection Manual, Effective January 1, 2009 50
M. HEADLAMP AIMING REFERENCE
1. HEADLAMPS - HIGH AND LOW BEAMS
a. Vehicle must be tested on a level surface. Always adjust lights to a setting of 0-0 when using a mechanical aimer.
b. REJECT when:
1) Horizontal aim is more than:
a) 4 inches to the LEFT or
b) 4 inches to the RIGHT
2) Vertical aim is:
a) higher than 4 inches UP or
b) lower than 4 inches DOWN
3) Vehicles headlamps are lower than 22 inches or exceed 54 inches, measured from the ground to the center of the low beam.
*NOTE: If a mechanical aimer is used it should be used according to the manufacturer's instructions and must be calibrated to the slope of the floor on which the vehicle stands. Headlamp aiming by the screen method requires a level area in a darkened location, sufficient for the vehicle and an additional 25 feet from lamps to screen. As of January 1, 2009, all new stations are required to have an optical or screen headlight aimer. PLT Safety Inspection Manual, Effective January 1, 2009 51
Figure P-9 (Reference SAE-J599d)
N. HEADLAMP - AIMING SCREEN
1. With the vehicle properly located and loaded, switch headlamps to high beam and observe center of high intensity zone on screen.
a. REJECT when:
1) Center is:
a) More than 4 inches RIGHT or
b) More than 4 inches LEFT of straight ahead.
2) Vertically is:
a) More than 4 inches ABOVE or
b) More than 4 inches BELOW the horizontal line.
2. When utilizing a headlight aimer the vehicle must be positioned properly in front of the screen.
PLT Safety Inspection Manual, Effective January 1, 2009 52
Figure P-10
VHADVerticalAim
O. HEADLAMP AIMING-ON-BOARD DEVICE
1. On vehicles equipped with V.H.A.D., aiming and aim checks may be performed on the vehicle if the vehicle is placed on a level surface. Preparation of the vehicle is similar to other aiming methods as far as loading and physical condition of vehicle.
