- Jan 24, 2008
I had the same problem until today I took the thermostat housing off and found the thermostat was not seated all the way there are two small tabs that keep it from going into the block and loosing its seal against the housing they needed to be spread out a little bit also the housing of the actual thermostat was just about blocking the hole for the heater core. I reassembled and now it’s nice and toasty.
Can you elaborate on this at all? I recently replaced my WP and stat and the engine is overcooled, running about 170° on the highway. I am thinking that either the stat isn't fully seated or the inside of the thermostat housing is corroded enough to keep the gasket on the stat from correctly sealing. Does this sound likely? Seems to me just about the only thing that could keep an engine from warming up is a fault in and/or around the thermostat. I did use a Motorcraft stat so it shouldn't be a case of improper fitment. It did lock in when I twisted it.
Maybe I'll try bending those tabs and making sure the stat is fully seated in the housing before buying one of these for $64:
http://info.rockauto.com/getimage/g...http://info.rockauto.com/Motorcraft/rh-35.gif
