- Aug 28, 2008
- Bremerton, WA
1988 Ranger XLT
2.9L 2WD M/T
The Ranger has BRAND NEW Fuel Pumps, and a BRAND NEW Relay...
{edit} I'm not sure if the CORRECT relay was replaced...{end edit}
I have gotten both pumps to run if I direct wire them to the battery..
Then I installed them, and when I cycle the key, the tank pump primes, like it is supposed to.
The Hi-Pressure Pump only gets 3-6v to it....
If I hook up a direct wire from the Batt (+) to the single connector under the master cylinder for the Hi-Pressure pump, the pump kicks on, and I can start the truck....drive it around no problem.
ONE TIME, and ONLY ONE TIME, I was able to pull the 'hot wire' out of the connector, plug the OEM one in, and it would stay running, I even drove it around the block this way. But I stalled in the driveway, and the Hi Pressure pump wouldn't power back up....so I pushed it into the driveway, hooked up the hot wire, and it fired right back up....
So....now what?
Ryan
2.9L 2WD M/T
So....now what?
Ryan
