agree. the stock box was the same box used on atleast the f-350's, maybe bigger trucks than that. the column is there and fits and matches, no reason to change something that works.
I'm actually using the steering box from my Bronco that the axles came from. Will run with the ranger ps pump and the shaft has to be "adjusted" to fit
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
