Body lift questions
I have a 2wd which on the coil spring bolts are short and do not have room for alot of washers so I would need extenders. I was just thinking of buying extenders and just using washers too. That might work.
as soon as i put the spacers in, i wish i just used washers. they dont give under pressure. and you could always add more or less washers. and remember, you dont actually need 2"s of washers, i think its like an inch and a half maybe? i cant remember. if you put a full 2inches of washers, you wont beable to allign it
the kit for 93's comes with fan shroud drop brackets and front bumper brackets, but no brackets for the rear bumper. if you look at the mounting brackets for the rear, you will understand. i have a PA kit on my truck, if you have any questions or need pics, let me know.
I have leveling coils and 31s, with room for 32s, so I don't know if you'll need the body lift. as for your gears, a friend of mine has a 95 Ranger 4.0 automatic, and had 3.73s and 38s for quite a while.
I'd say go with springs (mine were $150 shipped) and that helps if your old springs are sagging like mine were. Then find some 31 to toss on. If they fit, great! If not, body lift. then run it and decide if you want to regear. Or find a junkyard explorer rearend and have a wicked stout axle.
