- Jan 26, 2008
Ok, top to bottom, and thanks for all the responses guys.
My hope is to get this thing fixed and sold. I don't even have the new title in my hand yet, lol.
I'll definitely swap out the fuel filter tomorrow and see what that does, I'll try the converter thing as well. I looked again, the air filter is brand new. I'll throw a new one in anyway when I get the oil changed. I've heard the water pump could be the problem, wouldn't I have a heating problem if that were the case? The heater lines are hot after it's warmed up... no squealing noise or anything. How else can I check it?
How do I check the cat? Whack it with a stick or something? I'll check the vacuum lines as well. The guy who's putting on ball joints for me tomorrow offered to cut the cat out and bypass it for a minimum charge. Is that a good idea? It's too old for emissions testing so that's not a worry. Btw, LBR, I was just messing. I should have taken your advice, lol.
No Dex-cool in it now. It's green and looks clean, I may flush it out anyway if the problem persists.
The base gasket looks good, and fresh, they replaced everything above it. I'm wondering if they messed something up when replacing it...
So on to what's odd now, in my extremely long post; I did another read on the OBD and got the same thing, lean fuel reading. Then I reset it and drove it a good 1/2 hour. Granted, it is a bit colder today than it has been, but the thing didn't get above normal temp at all, even with the heater off, and didn't act up at all. It also seemed to eat more gas than normal, but it's hard to say. Is it possible that the OBD trying to compensate for the lean fuel somehow caused the engine to run hotter or cause the other problems? I guess I'll know for sure if it's still getting hot in a bit, I have to drive 1 1/2 hours round trip, to pick my son up. I'mma leave early so I can take it easy and have time to pull off and let it cool if it starts acting up again. Thanks again guys... This is why I asked here and not the jerks on the GM forum.
Btw... it immediately popped up the same warning after I reset it and drove it again.
