Thank You Ford (Wheel Bearing Content)
dasfinc
October 2011 STOTM Winner
MTOTM Winner
Boosted (Not Stock)
Warrenville IL
No Seriously, Thank you. My 00 4X4 that I just picked up had a failed wheel bearing (pads toast, rotor just about gone, caliper bracket chewed into) and i was DEATHLY afraid after finding this how bad it would be (Had a taurus, paid $250 for the bearing and had to have a shop press it in so I had to tear off the knuckle etc)
Found a new one on Ebay for the Non-Vac assist *again, thank you ford* for $60 shipped, Pulled out the old one gently with a prybar, and tossed the new one on in probably under an hour... I have NEVER had such an easy wheel bearing replacement on any vehicle I've ever owned!
My 98 was a 2wd and I replaced 'everything' suspension wise while I did the motor swap, but WOW did I not know the 4X4's were still this easy to service!
________
website design
Yeah, those are nice to replace. The disadvantage to them is that they fail predictably every 75K or so, and can be expensive if you get a Ford one.
or any of them...the masterpro house brand from orilley cost me 135 a pop and the timkens run like 250 a hub
My 1996 Ranger 2wd wheel bearings were pretty easy. Just had to get the bearing racers pressed in.
They are the same as about everything that ISN'T a unit bearing. My 1940's tractors are pretty much the same theory as my Ranger.
Wheel bearings are gravey money on just about everything. :icon_thumby:
86-06 taurus, or anything based on it (Windstar, Freestar, sable, etc) Are a nightmare...
I said just about.
I know the rear on a '02 Explorer isn't all that fun...
The Focus is brutal too. Front and rear. I would rather get a dental work done
I said just about.
Just had to give you some grief, I don't know any other fords aside from Mustangs/96-01 Explorers/98+Rangers/06+ Focus/Taurii (I've owned 7....)
