- Aug 6, 2007
- prosperity,SC
******2.9L FAQ.....Read BEFORE posting****** Options
General 2.9L Info
Years Produced- 1986-1992
Engine Displacement (Cubic Inches)- 177
Fuel System- MPFI (Multiport Electronic Fuel Injection)
Cylinders-6
Arrangment of Cylinders- "V" Shape
BorexStroke- 3.66x2.83
Horsepower- 140@4600RPM
Torque- 170@2600RPM
Engine Family- "Colonge"
Oil Pressure- 20PSI@Warm Idle 55PSI@2000RPM
Spark Plug Gap- .44
Ignition Timing- 12* BTDC
Fireing Order- 1-4-2-5-3-6
Distributor Rotation- Clockwise
Cylinder Location-
Front of Vehicle
4 1
5 2
6 3
Oil Capacity- 5.0QT W/Filter Change
4.0QT W/O Filter Change
Cooling System Capacity (Quarts)- W/AC- 7.2
W/O AC 7.8
Known Issues-
Cylinder Head Cracking Caused usually by overheating the Engine, most common symptoms are clean spark plugs, white exhaust smoke when warm, low compression on one or more cylinders, and "snot" on the oil cap or dipstick. Sometimes the "Snot" can just be condensation, so make sure the Engine is warm before checking.
Best Course of Action Park the truck, Drain the oil, pull the heads, and have them magnafluxed to make sure you have a crack, if you do DO NOT RUN THE TRUCK, coolant in the oil toasts crankshaft bearings, requireing a total rebuild. If the truck isnt run to long than you can probely get away with just heads.
Ticking Lifters Sometimes mistaken for ticking fuel injectors. This condition isn't a cause for alarm unless it does it very loudly or after long freeway trips., if it does have the oil pressure checked, it could be low.
Valve Cover Gaskets Other than making the Engine look nasty and smell nasty, these pose no danger. Some claims have been made of the motor catching fire because so much oil leaked on the exhaust, but this is rare. Replace with Fel Pro "Rubber" or Fel Pro "Blue" and leaks should be taken care of.
History of the 2.9L
Introduced in Late 85 on the 86 Models, the 2.9L was a larger, more powerful, fuel injected replacement for the old 2.8L Engine. It was born into the "Colonge" family of Engines which include the 2.6L Mazda, the 2.8L Ford, and the 4.0L FordMazda Engines. The 2.9 never saw duty in anything other than the Ranger and BII. Aerostars went right to the 3.0 from the 2.8 and Explorers used the 4.0 when introduced in 91. The 2.9 Co-existed alongside the 3.0, the Engine which replaced it, untill 1992, when Ford introduced a "More Refined" Ranger, the 2.9 wasnt a refined engine like the 3.0 "Vulcan". It was rough, noisy, and crude. The 3.0 was none of these things so it replaced the 2.9 in 93, even with its meager low end torque (compared to the 2.9) it still is the only Small V6 offered in the Ranger, next to the Big Brother 4.0. The 4.0 is related to the 2.9L however, so in a way it still lives on. The 3.0 is in NO WAY related to the 2.9L V6 Engine.
Links to Threads of Interest
Towing with a 2.9L
What Spark plugs are right?
Classic case of Dead Ignition Module (TFI) syndrome
Dos and donts of building a 2.9L for performance
NOTE
This FAQ is work in progress. As the Forum grows and more info is added to the board, the FAQ will grow with it. Then, we'll have a very large weath of knowledge and problem solving abilty about the 2.9L V6 Engine, all in one place. Also, any problems with links drop me a PM. Thank you
This post has been edited by rusty ol ranger: Sep 1 2006, 09:13 AM
87 Ranger XLT 2.9-TK5sp- Brought back from the dead- 10/08/06 11:32pm
01 Chrysler Town&Country 3.8L\Auto
04 Ford Crown Victoria 4.6L\Automatic
69 Dodge Charger 440 4BBL-4sp
77 LTD II 351W 2BBL\FMX Auto
78 Ford F350 400M 4BBL\NP435\2wd
"Boy somedays, you just cant cram it into second, even if ya double clutch it"-Cooter Davenport
"If I shake your hand, Look ya in the eye, you can bet your ass, it'll be the truth" -Eric Church "How bout' you?"
Yes I am a Redneck, and Yes, I'm DAMN proud of it!
Full Edit
Quick Edit
Michael A. K. Gross Mar 12 2007, 02:59 PM Post #2
Send Help Quick
Group: Banned
Vehicle Model: Exploder
Gender: Not Telling
Vehicle Year: 1991
2WD or 4WD: 4WD
QUOTE(rusty ol ranger @ Aug 9 2004, 10:22 AM)
General 2.9L Info
Cylinders-6
Torque- 170@2600RPM
Spark Plug Gap- .44
Sorry, Dustin; gotta correct a few things here.
This is a 60 deg V6, not just a "V shape." 45 deg and 90 deg V's also exist (and probably a few exotic angles), though generally in V8 applications. 60 deg is kinda natural when designing a crank with only three crankpins.
Oil pressure spec is 40-60 PSI at 2000 RPM, fully warmed. There is no idle spec, nor any cold spec.
Ignition timing is 10 deg BTDC with the "SPOUT" shorting bar removed.
Spark plug gap is .044. .44 (= .440) is probably impossible with a stock spark plug.
Idle speed is 800 RPM (manual) or 900 RPM (automatic) and is NOT ADJUSTIBLE (despite the thing that looks like a throttle stop screw). Make sure you test it with the electrical accessories (especially A/C) turned off.
Injector banks split the firing order -- NOT the engine. They are 1,2,4 and 3,5,6.
And FYI, the early 4.0Ls were related (but NOT with many interchangeable parts) to the 2.9L, but the later 4.0Ls are quite different.
Full Edit
Quick Edit
fastpakr Mar 12 2007, 03:02 PM Post #3
Habit, not addiction
Group: Members
Vehicle Make: Ford
Vehicle Model: Explorer
Gender: Male
2WD or 4WD: 4WD
A bit off topic, but VW's VR6 motors and the other related narrow bank engines (like the W16 in the Bugatti Veyron) run a 15* V angle. In the case of the VR6, this allows a single cylinder head on a V6.
Cologne is the correct spelling for the plant...
I demand that I be given access to my own posts and account on this board. Given that my posts and account were stolen and placed here, I expect at least the ability to access them.
Full Edit
Quick Edit
« Next Oldest · 2.9L Engines · Next Newest »
1 User(s) are reading this topic (0 Guests and 0 Anonymous Users)
1 Members: pimtool
Fast Reply
Enable email notification of replies | Enable Smilies | Enable Signature
General 2.9L Info
Cylinders-6
Torque- 170@2600RPM
Spark Plug Gap- .44
Cylinder Location-
Front of Vehicle
4 1
5 2
6 3
W/O AC 7.8
Known Issues-
History of the 2.9L
Towing with a 2.9L
NOTE
Full Edit
Quick Edit
Send Help Quick
Group: Banned
Gender: Not Telling
Vehicle Year: 1991
2WD or 4WD: 4WD
General 2.9L Info
Cylinders-6
Torque- 170@2600RPM
Spark Plug Gap- .44
Full Edit
Quick Edit
Group: Members
Vehicle Make: Ford
Gender: Male
2WD or 4WD: 4WD
Full Edit
Quick Edit
1 Members: pimtool
Fast Reply
