Andres629's still at it! '87 BII this time!
Andres629
Saskatchewan!
Update: Jan. 2, 2011
Decided that I would update the first post in my thread for any new people to see right off the bat. I will update this post as well as make a new post when more things have been done!
Didn't actually get any pictures of the VERY start of it, but close enough. '87 BII that I picked up for $375 CDN, with 265,xxx km on it, all it needed was a driveshaft. Original CV driveshaft crapped out. Imagine this with 205/75R15 winter tires, and a chrome grille and that's what I started with. On with the pictures!
After a little lovin'...
Plans for the very near future:
2" body lift
2" coil spacers, Expo springs/Belltech 6400's
Major fender trim
33x12.5 TSL's:headbang::headbang:
Jan. 2, 2011:
Wow, looking back on what I had planned at the beginning and what I have now is crazy! Here is my list of mods, and a picture in it's current state.
Mods:
-93 Explorer Dana 35's with 4.56's
-91 Explorer 8.8 l/s with 4.56's
-96 Explorer M5OD with early top plate and 92 Explorer clutch master and slave
-4.0 clutch
-93 Ranger BW 1354
-MSD 6A box, Crane P90 coil, MSD Super Conductor 8.5 mm wires, Accel cap and rotor
-1st gen Explorer front driveshaft on rear. If you have any questions on what you need to make this work, PM me. :icon_thumby:
-Explorer rear leaves with Belltech 6400 shackles, BDS shocks
-Superlift long arms, Tuff Country 1.5-2.5" beam brackets, 2WD Duff coils, modified factory coil buckets with F-250 shock towers, Bilstein 7100's
-Rock sliders and custom rear bumper
-2 sets of doors; full and half doors
-Major fender trim and new sheetmetal welded in rear wells
-35x12.5r15 Good Year Wrangler MT/R w/ Kevlar on 15x10 Rock Crawlers with beadlock
-Custom Aerostar grille mod
Before I got the outer bead broken and beadlock ring bolted on.
Did you make the front grill or was it already like that ??
Robert
you have way too many projects....reminds me of someone i know....oh wait...its me
Yep, Aerostar grille that I put together. I made it originally for the 88 2WD Ranger that I posted up earlier, then decided it would suit this more. It was really easy to do, and it turned out clean!
AHEM! Major fender massaging and some stock 4WD Ranger blocks under the rear springs to fix the sag... and here she sits as of today! :D
Whaddya'll think? I dig it. =]
Thanks slo-vo. Now I just gotta get me a front and rear bumper fabbed up and some sliders!
Needs more regular cab Ranger cab and bobbed, dovetailed Ranger box. :D
I think it needs a set of fender flairs, and then your done, it looks great the way it is.
also I dont know what it is about BroncoII's, but mine 89 felt like I was driving up hill all the time, I stuck a 2 inch block in mine also to make it look level
Robert
It's in the works... I don't want to get an MVI on this one like I did on my Ranger. I'm going to either make some out of some 18ga checkerplate aluminum, or use old conveyor belt. So far I'm leaning towards conveyor so that WHEN I rub it against a tree, it just folds over and goes back in place, rather than bending. :icon_bounceblue:
