Junk Collector
⭐Supporting Member
Truck of Month
Need some advice... what is everyone running for electric fans? I don't have enough room to run a mechanical fan, so I'm looking at doing an electric fan setup. I have about 3", maybe less between my pulleys and radiator (I have the Duff 4 core rad) and currently two electric fans, one around 14" aftermarket one and a smaller one from a Chevy pickup. The 14" is in the engine bay as a puller and the Chevy is behind the grille as a pusher. It is still getting pretty warm but might just be air stuck in the cooling system... just want to get some options in case I need to get different fans.
Second question, I am using an NP435 with a bellhousing from an '84 F150, and flywheel and starter from an '82 Bronco. When the engine is running it sounds like there is a bolt rolling around inside the starter... think really loud rattling noise. I think I may just have either a bad starter or simply the wrong starter for the bellhousing... supposedly the '84 took a different starter than the '82.
Thoughts?
Thoughts?
