- Dec 27, 2009
- Age
- 48
- Fenton Missouri
I have a 02 F-150 4x4. I have been searching what seems like for months on doing a SAS on my truck. I have read through several build threads on here about SAS on a RBV's and was wondering if anyone had some good info that I could use for my 150. I have posted this question on some other forums and have recieved very little if any responses.
Here is what I am planning on using
99-04/5? F-250 super duty axles D-60 up front w/ Ford Sterling 10.25 rear.
I know that the SD axles are 8 lug and that they have the setup that I need w/ 4-wheel discs and the Abs. I DO plan on driving this on the street so I was wondering if coils up front would be the way to go-all the pics I've seen on the net about this swap all use leaf springs for the front and I would like to use coils for a better ride.
Is this a really hard swap to do? I know a LOT of members on here have swapped to full-width axles on their rangers and such and the 98-up ranger has a simalar setup as the f-150. I figured it would be pretty much the same just the truck and the parts would be larger.
Any info/help would be appreciated greatly!!!!
Keep em comming!!!ok so I know that the swap will not be easy and cheap by any means. IMO I feel that w/ todays IFS the OEM's kinda "cheaped out" on the quality of the parts for the front end.{I.E sealed wheel bearing assemblies,CV shafts and the like}
Ok since the "old" stuff uses unit bearings as well I guess I will not be gaining anything if I do a SAS. I was looking to get a RCD 4" lift next spring and I currently have 33" BFG a/t's that are only a year old. I am planning on going to 35's after the lift but I have to wait until the 33's wear out. Would a lift and my current 33's look stupid until I NEED to buy tires?
