- Aug 14, 2010
Just picked up a 2000 Ford Ranger XLT,3.0 4x4 with 30k original miles.
Obviously the truck has sat for a long periods of time inbetween uses. From sitting moisture as taken its toll on atleast 1 brake line and the vacuum line that goes to the hubs
My first question is brake lines, is there a company out there that make replacement lines OR should I just make up my own. I'm talking about the steel line that screws into the rubber line for caliper
Second question is on the Hubs.
I noticed that there are two lines that seem to come from OR go to the hub, One is a vacuum line and the other electrical. I think its safe to assume that the truck has ABS and the vacumm actuated hubs from what I gathered on the site so far. Where the vacuum line attaches to the nipple it is VERY rusty and has blown up the vacuum line and i think IF I touch it or with use it will just break apart as it looks VERY VERY brittle
Where is a good place (quality and cost) to get replacements? Would like to stay with the automatic hubs.
Just found these two problem areas while I was under it today. I sanded down the suspension parts and the frame, I primed everything and painted it all up to prevent any other rusting, It was mainly just surface rust which I was very pleased to find.
