fuel cell...with stock pump and sending unit
86 slo-vo
02/2011 OTOTM Winner
owensboro, KY
anybody have any ideas on what i can do? dont really want to build my own cell but would like to mod one to accept the factory pump
any idea's would be appreciated
I thought about it for my race truck but that's as far as it got. I have a bladder inside a steel can and it would have taken too long to fab something up. But I thought of cutting the top off of a steel tank, then drilling the holes around the perimeter to fit my cell;
Richard
i got a used aluminum tank from a boat. 27 gallons of pure joy! the filler hose cost as much as the tank, $50, but was worth it when it was all done. added the line and my main line into a manual switch (new from a boat parts store) right next to the driver's seat. i use the boat tank 1st as there is no fuel gauge for it, when the truck sputters, i switch to me original tank that does have the gauge. with the 21 mpg's i'm getting, i'm good for just over 800 miles between fill-ups on long trips. yeah, i'm a very happy camper!!
so you have 2 tanks with 2 different pumps or one tank dumping into the other?
have any pictures?
I've seen pics where somebody did it with a plastic fuel cell, but I can't remember the site or post....SORRY!
I thought of doin somethin similar with a Bronco II tank, but decided to go with a Harwood 12 gal. fuel cell.
im tempted to go ahead with a b2 tank...
the deal is im going to a tube bed and i want the tank out from under the truck, getting tired of dragging it across the rocks
whatever i use will be going right behind the cab on top of the frame rails
2 tanks. fuel line for the aux tank in the bed goes to a manual switch that comes up right next to my seat. original tank line goes to the same switch. mine being an '83, mechanical fuel pump on the motor. all i do is turn the switch to whichever tank i want to use. simple and nothing electrical to screw up. the aux tank is 48" x 18" (approx due to shape of the tank), x 7" high and holds about 27 gallons, mounted right up to the cab end of the bed. fits like it was supposed to be there.
oh ok, didnt realize you were carbed....
i dont have that option i have to have a high pressure pump
I used a stock '88 F-150 2wd 5.8l frame rail high pressure pump [what I had handy] and bought a low pressure suction pump, mounted directly in front and above the tank.
From the tank, of the 3 blue fittings - the one on the right
to a clear fuel filter
to low pressure pump
to fuel filter [fuel line size adapter]
to fuel accumulator
to high pressure pump
to 'stock' fuel filter ([used as male to male adapter]hidden behind green drill)
connects to line where original tank used to be;
It looks fugly but it works.
Richard
anybody have a stock ranger pump out that i could get a length measurement on?
your bed is off.....why not pull your own pump......
l8r, John
because im sitting at the computer :thefinger:
you have just hit a new level of lazy.....:D:thefinger::D
i will post up a TB "break in" trip for you..........in about 3 MONTHS.....
l8r, John
lol ill pull it out tomarow and see what i can figure out...might just end up going with a b2 tank
........or a wrangler tank sitting by my garage...lol
well.....you know what i got in it......:D
i'm sure i could find another......i just really need to see if it will fit where i want it to....
l8r, John
