Aftermarket Shifter for A4LD
nd4spd71
10+ Year Member
I am swapping a A4LD into my B2 inplace of the 5speed. I am trying find an aftermarket cable operated shifter to use but don't seem to having much luck finding one that lists the A4LD as an application. Will one for an EOD work? What have others used? Any info would be great. Thanks.
u might have to buy one for a c4 or aod and fab up some kind of cable, i know lokar makes some different cables u can use. i know they did that in petersons 4wd mag a while back on some rig, i dont remember what it was though
One problem with using one for a c-4 is that it is a three speed and the a4ld is a four speed there fore the detents on the shifter that lock it in gear will be missing a detent. Why not try one for a newer mustang and just build your own console around it?
I used a B&M truck MegaShifter setup for a 4spd. This works really well but it is a ratchet shifter
You could always stick with a 5spd and avoid all the "fun" that comes with a4ld's lol. Are you looking to put in a floor or column shift?
in no way do you want to do this.
He has his reasons. The a4ld was a weak tranny and almost any 5spd (fm145, fm146, m5od) would do better. We shgould support his choice and do what we can to help him out! This TRS!! We are here for eachother!!
fine, but i call dibs on his 5 speed and shifter.
Perhaps you could use the floor shifter from an aerostar.
I know that floor shifters are out there for the A4. I knew a guy who had a floor shifted A4, and I think I saw one in my local JY once, but I can't remember where it was.
my bronco II has a floor shifted A4.
just throwing that out there.
edit: actually, you do NOT want a floor shifter for your b2, mine has about nine miles of the most cluster-**** linkage i've ever had to fight with.
Art Carr, Hurst, and B&M all have shifters that work, Art Carr has a nice installation manual with pics on their website. I am putting and auto in my BII because of some knee issues. I still like to hike so I want to make everything else a little easier on myself. My Ranger is and will remain a 5-speed. But if I was you, I would look in the junkyards for a ranger or BII with a floor shifter and get all the linkage. Just a lot easier to see it there and reproduce it on your truck. I put a column from an explorer in mine. Just a simple swap, easier than most would have you to believe.
Thanks all for the responses. For those that have asked my reasoning for wanting the auto is my wheeling experience has always been in automatic vehicles.....just more comfortable with them. I do have an auto shifter from a b2 but am missing the linkage from the shifter to the trans. And as someone mention I have seen the linkage in a b2 and it is crazy looking with frame connections etc. Just was thinking an aftermarket cable shifter would be easier to install and maintain. Good idea on the aerostar shifter, will have to check one out and see if they are simplier. Does anyone know if a shifter listed for an AOD would also work on the 4ALD?
And his b2 has a 3" BL making it that much more fun.
This is actually in my garage right now, We didn't install the A4LD or remove the 5spd we got it half installed and unforntantly missing alot of pieces to the puzzle. His b2 is also a first gen so installing a 2nd gen column or an explorer column isn't usable unless we convert the interior to a 2nd gen.
