Junk Collector
⭐Supporting Member
Truck of Month
Nope, you will have to remove the valve covers though.
sounds easy enough. How many are required for a full set
Could bad valve stem seals cause the dip stick to read no oil in the oil pan after the motor warms up, but read normal after shut off for about 20 Minutes.
thanks I may try it this weekend. Will i have to drain the oil?
Let's talk about this a bit. First of all if there is oil coming out the tail plpe the muffler is about 1/3 full of oil! If that happens there WILL BE an oil fire UNDER your vehicle..
My point here is you have disoriented yourself. That WAS NOT oil you think you saw. Most likely you saw some condensation that was full of soot and was blackish.
So whatever you do to that engine forget about oil in the tail pipe. Fix whatever you want to fix, but do the fix'n without the oil in the tail pipe in mind.
I'm surprised at the answers you have got and none of them even THOUGHT about how hard it would be to get oil to drip out the tail pipe!
So if something else is wrong with that engine go ahead and repair it..
Big JIm![]()
Oil vapor can travel throughout the entire exhaust system. My buddy has a 400 in a '79 F150 that will literally spray oil droplets out of the exhaust if you get into the throttle really hard.
I agree that it is highly unlikely that the muffler is full and that it very well could be condensation. I am just going by what he said, if I saw something I thought could be oil coming out of my exhaust I'd feel it, smell it - whatever it takes to identify it, so I assume that someone else would do the same.
C'mon! Enough with this vapor crap! Oil vaporizes and turns to smoke! It don't recreate itself into oil again.
It is possible for oil to come out the exhaust...ONCE! In it's last gasp!
Any oil that gets into the chamber gets burnt.. If some doesn't get burnt the plug will foul and start missing.. Indicating the demise of the engine.
She's been so rough this week I had to down grade to the Buick
I was wondering the same thing throughout reading this entire thread.I'm surprised at the answers you have got and none of them even THOUGHT about how hard it would be to get oil to drip out the tail pipe!
It'll probably get burned by the 1000°F+ exhaust gases leaving the cylinder?So if the exhaust valve seals are leaking oil into the combustion chamber during the exhaust stroke (when the plug does NOT fire) where do you think that oil goes? You're right, it will foul the plugs, which he indicated here:
Because I have THOUGHT about the problem! Little if any oil enters the chamber from the exhaust valve seal! If anything compressed mixture will go backwards into the engine out of the chamber during the exhaust cycle. It is the intake valve that has the suction on it and awards the chamber with oil.
Look man, I don't want to argue. I am just telling it like I've seen it.![]()
