- Jul 7, 2008
I never know how to start a thread, so first, the back-story:
I got a 1995 Mazda B2300 from my dad last summer. I've known/driven the truck most of its life. It currently has 225K miles on it and back in december, it got put in the driveway. And it sat. I call it the doom truck (plate is DOOM TRK)
Around the end of may, I finally had a chance to figure out what broke, and start fixing it. The safety inspection had expired last december (2009) and registration had expired in April.
In a month, visiting my parent's house after work (full-time software developer), I managed to fix:
This brings me to my current predicament. When idling, with the air set to 'off' the truck is fine, no problems to really complain about. When I turn the air/ac/max ac on (any temp any fan speed) the voltage starts fluctuating and the idle gets slightly rough, and then about 2-3 times a minute, the voltage will drop a LOT and you'll basically hear a missfire (as if the timing was dropped significantly, or the spark never happened) and the voltage needle will drop and all of the needles on the dash will begin to drop due to lack of voltage. if I just tap the gas pedal however, everything is fine; the needles go back to the correct position, voltage goes back up, truck sounds happy. When I'm driving, there is no issue with voltage.
I've done a bit of research and I've already decided I'm going to redo the +/- wires from the battery since they're the original ones that came on the truck. The battery is good (it had damn well better be, I just replaced it because I left it connected for 6 months and destroyed it).
I'm wondering if anyone can offer any suggestions of other things to check, I just found it weird that it only seemed to happen when the blower was running.
Things remaining to be fixed on my truck:
Thanks!!
- Rear leaf spring mount (drivers side)
- Blend door (the hybrid-hard way)
- fuel filler neck
- seafoamed the intake (NOT the oil)
- Voltage-drop@idle ONLY w/ blower running
- Washer-fluid squirter doesn't work
- Alignment (not looking forward to this)
- Fix steering (might be related to pitman arm or alignment)
- Repaint the bed / cut fender rust
Thanks!!
