- Jun 1, 2001
- Age
- 64
- 1987... sorta
A good chunk of this incorrect to start off installing windows 7 onto a previously windows xp system will always cure a virus issue this is because you cannot simply use the upgrade function like xp to vista or vista to windows 7 you are required to do a format and install. This will also fix the fragmentation issues on the system as a full format erases the tables etc. This will give the user a fragmentation free drive. With the new install cc cleaner will not e needed personally I find programs like that as a waste of time and bandwidth half of the thing cc cleaner does is built into the windows command "msconfig" you are correct that if a drive is full an os upgrade won't help but I am confused what it has to do with anything posted in here...
Now as for the I have avg and never got a virus that's like saying I have never been in a car accident so I don't need insurance. You get what you pay for avg, avast and the other free antivirus programs do prevent some virus's they are however not very good and miss more than they catch good pay for antivirus programs are kaspersky, nod32, and trend micro pro. I personally use none of those I instead have no av protection since I know how to avoid them. Ie don't open bogus emails don't click popups and use care when downloading. The last virus I had ran under the name of mcaffee and that was even paid for :/
Actually a "clean install" is anything but.
you should look at a fragmentation map of a VIRGIN drive that you've just installed XP onto
And look how much crap you delete running "Disc cleanup" after your first manually triggered
"windows update" after doing a "clean" install
THEN run CC cleaner to see how much stuff Disc cleaner missed.
Doing a clean install on a computer and running all the updates usually takes me all day
(but I can run four or more systems at once because much of the time is spent waiting)
By the time you can get a pressed disc there are typically around 100-130 updates that windows automatic update is going to want to install, but you will never get them all on in one go, because in the process there will be 5-6 restarts to install parts that are necissary for later upgrades.
If you let it run "automatic updates" daily it takes seven to ten days to finish making a hashed
up mess of the OS drive, running disc cleanup (in disc management) CC-Cleaner and defragging
the OS HDD between each forced session of updates speeds the process enormously.
I've actually achieved the allegedly impossible... a complete install with ALL current updates
and ZERO disc fragmention, infact I did it five times on five seperate systems over the
weekend.
Ofcourse if all five systems had been identical Dell systems I wouldn't have needed to...
I would've just done ONE system then CLONED the drive four times.
Because on a Dell the OS doesn't know (or care) about the MoBo Serial number.
you can freely swap WinXP and Win Vista drives between systems without major issues
Oh yeah, if there are hardware differences you get to install the proper set of drivers
for the specific hardware, but....
My personal motto is "Dell the ideal computer for an IT guy who'd rather spend his time
playing World of Warcraft or browsing ebay"...
Before considering upgrading to windows7 you also need to go to either Microsoft.com
or HPSupport.com (or your computer manufacturer's webside as appropriate) then
download and run "windows7 update advisor"
this will tell you what needs to be done to upgrade to Win7, if it's even possible with your
specific model.
You may have hardware as well as driver issues that prevent upgrading
to win7
I know on my Dell notebook (factory Vista Basic) I must use some vista drivers and there are other Win7 specific drivers I need to install to run Win7.
I have the Win7-Pro install disc sitting here on my desk, but I'm not doing a thing to my current
install of Win Vista-Basic.
Because my current Win Vista basic is on a 160gb drive, I'll install Win7 onto a virgin 320gb drive that's still sealed in the WD anti-static bag
So worst case is I'll have to swap drives back and forth until I get Win7 "dialed in"
