power steering
pismoduners
10+ Year Member
does anyone know how to and what fits, to put a power steering on a 1990 4 banger ranger. thank you
bump for answer
Which engine, the pump its self or the gear box ?
grab the pump with bracket, gearbox with pitman arm and the two hoses between them from a '89-91ish ranger 4 cylinder as they will have the same type of setup, any newer and you might have to grab most of the brackets for alternator and such
Eat a power bar and be a man:D. My 93 has no power steering works just fine. Sorry I could not help my self.
same pulley with and belt type on an 89 though ?
the front end of the years listed should be very similar, if you go to the junkyard and find an unmolested engine take all you can including the belt, there's not much to change, everything mounts off of the power steering pump bracket including the idler.
