- Jun 7, 2010
I have a 97 mazda b2300 that I used to drive before I got my current car. When I was still driving the b2300, I had an issue where the rpms would drop when I press the clutch in and break for a stop. They generally drop low enough to kill the engine. This only happens while the engine is cool, sort of. If i just let the engine warm up, it will continue to die when I let off the throttle but after driving it around for 15+ minutes the issue diminishes and then disappears. I had to drive the vehicle 30+ miles highway at the time and I found myself fighting this issue all the way to the highway and once I got on and off the highway, the diving idle would vanish. The car has since then set until I recently decided to get it working as a daily driver. Out of searching and reviewing old threads with similar issues I ended up replacing the IAC, cleaning the maf, changing fuel filter, changing fuel pump, and since I had an EGR low input code or whatever, I replaced the DPFE sensor. I vacuum tested the EGR Valve while the car was running and the idle did not change however I could hear the valve open and there looks to be minimal buildup in there. There has been no CEL since I replaced the DPFE sensor. Besides the issue disappearing after the engine is warmed for a bit, it almost seems like a Vac leak. I sprayed starter spray throughout the engine bay with no response from the running engine.
All of this was done but the issue is still there. Where do I go from here? Is there a possibility that autozone sold me a bad IAC? Any suggestions on what to do next? Thanks guys. I will probably be frequenting these forums more often since I plan to be driving this beast again.
p.s. I had to replace the fuel pump and filter to get the truck running, the fuel pump was dead.
