- Jun 1, 2010
- Hattiesburg, MS
My 98, with 2.5L SOHC, has been having power problems for quite some time now. After a compression test and finding very low readings I pulled the engine for rebuild. Found the reason for low readings to be broken comp rings on 2 cylinders. Bored block .030, had crank turned, head shaved, and had valve job done. Put it all back together with new injectors, TPS, IAC motor, crank position sensor and Mass Air Sensor. It runs far better than before. the problem is that it shill has no top end power. Hooked it up to scan tool and at idle it shows the ign timing to be at -3 deg even though a timing light shows +8 - 10 deg at balancer. Checked another 2.5L Ranger with same scan tool and it showed +12 deg ign timing while at idle (did not check this one with timing light). I am old school (don't know much about computer controled engines) but I know that if timing is retarded you get loss of power due to it. I think this is the problem I am having here but don't know how to change the ign timing or why scan tool and timing light would show different values. I am really stuck and need some help please. Is there a way to test the computer itself to see if it is bad? What should I do next?
I rechecked the fuel pressure as modelageek's suggestion. Got 65 psi with engine not running and 61 with the engine at idle. This time I didn't stop here, I went to WOT and the engine fell on it's face just as the fuel pressure dropped to 25 psi.
I hooked up a tach and repeated the test watching the pressure and RPM. I slowly raised the RPM and the pressure started to fall. By the time I was at 3800 the pressure had dropped to about 40 and that's when the engine took a dive. The more I opened the throttle the lower the pressure until it bottomed out at about 25 psi. The pump and filter are only a few weeks old so I suspect there to be a fuel line restriction somewhere. I can't beleive I have not thought to check fuel pressure at anything above idle. Not sure what the deal is with the timing is but I think the fuel pressure is the root of this problem. I believe that the first step is to get enough fuel to the cylinders for the timing to have a chance at it.
