Okay well I'm not sure that it's just a bad valve body anymore. I completely lost reverse the other day as well. So there's a no shift into OD in OD, and a no shift into 3 in D, plus no reverse gear. Am I going to have to replace bands and clutches and all that hoo-haa?
The direct drum cluthces are gone. sorry to tell you but it needs a rebuild, or at least a soft rebuild.
If you do the rebuild your self it would cost $400 max, but shops charge $900-2,100. it sounds hard, if you break it into steps its quite easy.
