- Jan 20, 2008
- Grants Pass, OR.
Hope there is someone out there that can help answer a question. I had posted in the wrong forum (being a newbe) but finally figured out how to make this work and wanting to get involved. having said this, here is my problem...
Just bought 1992 Ford Ranger W/2.3L 5sp. 2wd that has been sitting for approx 1yr. Owner went into service, had said clutch was bad. That was an understatement since the springs were busted and one completely out of the carrier. So... I Just replaced clutch/slave cylinder/pressure plate/input shaft bearing...bled system and have clutch. Replaced transmission fluid (never been done/has 72K on odometer). Fluid was very dirty. Transmission moves through all the gears stoped and clutch disengaged like it should. However, when I drive the truck and shift from 2nd to 3rd. it does not seem like I can find 3rd gear. I did find that if I then went to 5th over, I could come back and it would go into 3rd like it should. In addition, I could now shift 1st.2nd.3rd. 4th. and 5th. without problems 3-4 times, then 3rd gear would act up again and I would start the process over again by going into 5th and back into 3rd. Help!!!! This thing is driving me nuts
