- Aug 29, 2009
im looking for a rubber grommet for my cb radio antenna cable. i drilled a hole in the door of my bronco II to run the cable through. anyways i need a rubber grommet that will allow the bigger end of the coax cable thorough but also will be snug on the cable so water wont get in. so basically the inner diameter needs to be smaller then the outer diameter. what do i call these and where can i find them?
