ive been bouncing a few ideas around for the 2.9l and my gf brought up the idea of tt t3s, the only problem i could foresee is the engine management. other then internal engine what does everyone think of this?
Good luck finding someone.
You're either looking at a custom engine management system, like a megasquirt, or trying the MAF PCM. JP3/BBR has claimed that the MAF setup worked fine for his setup. But that's a lot of boost. Best bet is to aim low and slowly make your way up - a goal for that amount of boost out of the box on a custom setup like that, is just asking for failure.
i recall a mass air flow set up for the later 2.9s...i think 92? if you swapped over to that set up you may not have to worry about a custom tune set up
bump in displacement and a stand alone management system would be perfect.
isn't that always the case?
putting a single turbo onto the 2.9 would likely be as much work as the simple 4.0 swap. maybe a touch more but would net gobs more hp. the cost of the turbo would be
1, the turbo unit
2, the manual fuel pressure regulator
3, manual boost controller
4, blow off valve
5, various small "odds-n-ends"
6, duct work. in the past for the intake ducting i have had exhaust shops bend the pieces i need out of 3" exhaust, and bought 3" 100psi hose from "evco house of hose" for $12/foot.
7, modification to your exhaust. usually pretty minimal
8, oil feed/return lines i usually use a "T" in the sending unit threads. and just dump it back into any number of places in the motor
i usually find a stock turbo'd vehicle at the junkyard and get most of the hard parts from it
You could then turbo your new 4.0 powerplant and have a more powerful and reliable system than the 2.9 would provide.
