it is pretty tough to DX a squeek thru the internet. i originally had these chrome rings that went on my rims(sort of like a hubcap) mine use to squeak. i removed them. a loose front end part will usually be more than just a a squeek. you can jack up each tire and move the tires and parts around and see if there is anything loose. Another thing you can do is spray the stabilizer bar, the control arm bushings, etc with silicone spray.....if the squeek goes away you found the issue.......
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
