- Dec 29, 2008
- Near Lima, Ohio
Ok. I looked at the tech library and got most of my answer from there however i just wanted clarification. Do the 7.5 and 8.8 axles out of an Aerostar mount up to a Ranger without modification?
Also i currently have a 7.5 with 3.73 gears. I'm looking to upgrade as i went from stock tire size to 31 inch tires. I looked at the chart in the sticky and it said 4.56 gears is what i should use but could i get away with 4.10 gears? The 4.10 gearing setup seems easier to come by in my neck of the woods. Also if I would jump up to an 8.8 as long as it's out of a ranger will it mount up fine? I'm thinking as long as it's from 93 up it should work.
One last question here, sorry i have to ask so many questions. If i were to swap the rear end out doesn't the axle basically float down after you undo the U bolts? Then it's just a matter of disconnecting things? My dad was trying to tell me i won't be able to do it and it's hard, from what i know from working on and under it, it would be a time consuming task but with patience it can be done. I figure as long as i go with an axle that would mount the same and has the 9 inch drum brakes on it shouldn't be too hard.
Dan
Dan
