whats the difference between 03 to 07?
07rangerfx4lv2
Ontario, Can.
is the only reason an older 98-03 hood won't fit a newer 04-07 style is because the new style of grill?, if i were to replace the grill with an older style grill could i fit an older style hood?...im thinking an aftermarket cowl hood, thanks.
new math
If my math is right the difference between 05 and 07 is 04:icon_rofl:
The differences externally between the 01-03 Ranger and 04+ are:
Header panel
Grille
Hood
Valence change(for 04-05), full bumper/bumper cover change for '06+
hood latch
driver hood hinge
Yes......the grille is taller on 04+ compared to 01-03's, and the header panel is different to accomidate it.
Here's a side by side....'01-03 vs. 04+...
Now you know....if you know how to work 'glass.....you can have a cowl hood on your 04+......
Clicky: http://www.justtruckin.net/pages/CowlHood.html
That cowl is actually a cowl made to adapt to just about any hood. Click the link and you'll find where he got his at.
yea i thought about the stick on ones but i need a new hood anyways, mines slightly...used...so to replace mine with an 01-03 i would need to swap out the whole header panel+grill? I would love to do something like his but i definatly don't have the skills or money
As to skills, its a really easy swap. Everything just bolts up. I just swapped my 98 to an 01-03 setup, only took a couple hours.
Money, on the other hand, can be an issue :icon_twisted:
Header panel
Grille
Hood
hood latch
driver hood hinge
So are the fenders the same? Everything i find shows them from 01-03 and then 04-10. Will a 00-03 bumper bolt right on to a 04 frame?
the fenders are the same since 98
a 01-03 bumper will fit any 01+
with the proper brackets u can fit it on any 98-00 and a 98-00 bumper on any newer ranger too
fx4wannabe01......are they the stock headlights? they look stock but are darker around the beam, like a projector
u can open them , paint the housing and u got proyectors :icon_thumby:
i think theres a how to on the tech library about that.
