Hey everyone, my name is Kevin, and my work just bought me a 1995, 4cyl ranger.
It has a some electrical problems that I believe might be related...
The first problem is that the high beams do not work. I have brand new bulbs (both high and low) but when I switch to highs they turn off completely. I haven't checked the fuses yet.
The wind-shield wiper works- kinda. There is a long delay before it actually turns on, and I even had it go on in the 'off' position. The windshield wiper water doesn't work at all. I have yet to check the fuses on this one either, but I don't think it's a fuse problem. Both blinkers work fine.
Also, i'm looking for the easiest way to increase gas mileage/performance. I've done some research and have found this 'gas saver'
I've also found this chip
Anyone with experience from either?
Any recommendations on where to find a good repair manual?
Has anyone had any experience with a hydrogen conversion?
Thanks in advance!
Thanks in advance!
luck with my gremlins. Are there specific chassis grounds I should be looking for, or just checking around the engine bay for corroded wires?
