winslow rocks and water pics
spdcrazy
Homer, alaska
mostly 86
had a blast. although i now realize i want a locker!!!
Sweet Bii!!
Can I get some more pics and specs of the hood scoop? I wanna do a similar setup but an inlet
Sweet Bii!!
it is an inlet!!! i've been in the process of updating my B2. it was build well, but over the years it just needed to be a bit more up-to-date-ness. it had a circluar hole with some ghetto round hose thing on it, so i had to improvise. used some thin sheet metal. and made my template outta cardboard. then cut and bend it using a rubber mallet, c clamps, and some scrap strap metal to keep the bends straight. then drilled and pop riveted it on.
under the hood i just used the stock air box and took the top off if i remember right. gonna build a custom box with a k and n filter soon.
just make sure ur material is thick enough that the wind doesn't let it vibrate like mine, it will end up cracking!
Sorry, I meant inlet as in not a scoop, nothing showing above the hood line, a inlet like on the old 69 charger hood
ohhh nice. i like the idea. and offset would look cool. maybe a bit different shape somehow tho. keep us updated!
Check out my build thread, in my sig, to stay updated. The AC is in the way righ tnow, but that should be coming out this summer whether my dad likes it or not:thefinger:
