4.0 or V8 swap from 3.0
konstrukt
10+ Year Member
Is it worth it to swap a 4.0 with a 3.0 or should i just go ahead and swap in a V8.
do you mean replace a 4.0 with a 3.0? thats kinda how its worded. i'm assuming you mean the opposite. unless you need a lot of power/performance, a 4.0 should do fine. i have the 4.0 in mine stock. it has a lot of power.
4.0 would be fine for power i'm happy with my power plus i think a 4.0 would be easier to swap in also.
Depends!
Either one is such a nightmare to undertake it is almost a must to simply sell that ride and getcha another one with the engine you'd like.
First you will need a total donar vehicle and then you will have to swap all the parts over from it to yours.. Everything must be swapped..includeing the tail pipe and the radiator and everything inbetween.
Big JIm:hottubfun::wub:
thanks for the input
