dana28 to 35... driveshaft
lethal-threat-b288
plant city, fl
ok so in in progress of swaping my axles. d28&7.5 to d35&8.8
i read that my driveshaft has to be shortened/ cant i use the front shaft from my doner ranger?:icon_confused::icon_cheers:
the ranger is an 92 it has same tranny. a4ld. and it has a 2.9. im keeping the ranger to use as a daily driver. after i swap the axles. and im not lifting it im just goin to run some 235/75/15 trail diggers just incase. only thing is that the vin# is gone from the dash but i got the # from the door and need to get a title. my friends grandpa gave me the truck for 50 bucks and i drove it home after i took the thermostat out and put fresh gas in it. suprisingly the thing started right up.
I have a 86 b2 came with a auto and a 1350 and a d28.Parted out a 90 ranger came with a auto and a 1350 and a d35 measured the drive line exactly the same length.Left me kinda wondering.I thought I had a drive line for a swap but I don't.
You can use the donor's driveshaft if you also swap in it's 1354 t-case as well.
Mine both had 1350s in them can you put a 1354 drive line on a 1350?
By the way 4x4 Junkie I found your Suspension article in tech section very helpful.
No, that's why you have to swap the t-case to fit the driveshaft (the front output on the cases are different). If you had a truck with a D35 and a 1350, something's been swapped at some point on it.
Glad the article helped :icon_thumby:
The 13-50 was NEVER factory installed in a D35 RBV.
There is NO factory driveshaft to connect them.
AD
