happilymarried
- Mar 21, 2010
Okay, I've searched through the forums, and haven't really found anything that sounds like my exact problem.
I bought my 84 BII about a month ago with a new battery in it. It takes a bit of time to start w/ the oil-fouled plugs from my leaky valve-seals that I haven't been able to replace yet, but I had been noticing the speed of the crank slowing the past couple weeks. This morning it slowed to a halt and wouldn't start. Jumped it and it fired right up though. Barely started on its own and drove home tonight with lights on (not flickering or dimming or anything).
My question is basically: am I correct in assuming my alternator is fine but my charging system is not actually charging the battery, leaving me essentially only so many starts before I've worn down the battery and need to charge it?
The wiring throughout the truck is definitely old and has been messed with. I have found several places where the insulation is missing around the wires (actually, saw that on the back of the alternator this morning, but haven't had time to explore it thoroughly), and there are a few things that just aren't even hooked up to anything. I haven't seen a battery light (or any warning lights, for that matter), so I'm guessing that is either not hooked up or burnt out. Would these be creating a constant drain on the battery? My only doubt about that is that it took a whole month to drain the battery and it was very gradual. I had a short develop on another truck a while ago and it didn't take a week to suck the life out of that battery.
I don't have a ton of time to work on it in the next few days so it would be awesome if someone could point me in the right direction so I could get it fixed quickly (as if "fixed quickly" and "electrical problems" ever go together in the same sentence). Thanks!
