Damned thing!!!
'99 EB Explorer
Sudbury, Ontario, Canada
Ok...so my '99 Eddie lost reverse AGAIN!! :shok:
At this point I'm thinking about putting in a C4 or C5 to replace whatever garbage transmission is currently in there.
Now the question part...
Would it work?
What would I need?
Any tips/ideas/etc???
Is it even possible to bolt up to a SOHC?
I've had enough of this issue...i'm really considering a jeep later this summer if this keeps up. :annoyed:
Any help would be appreciated at this point.
Thanks guys 'n gals
hit it with a hammer
go manual.
Ok..I thought of that too. Is there an adapter plate to mate a 5-speed to a SOHC 4.0L?? And if there is, has anyone ever re-located the "computer" from the center console on an Eddie? I know there's going to be a lot of plastic needing to be cut and removed if I go stick.
They say that a 4.0 M50D fits on a sohc all but one hole and they work.Imho ford did'nt make very many good automatic transmissions.
Yeah they have a 5 speed stick for the SOHC 4.0L All newer rangers have the SOHC and many have the M5OD so just grab one of those, if you can find a wrecked ranger get it as a cheap parts truck so you have everything you need.
I have a box for 4x4 under my plastic thing it is right behind the shift and isn't in the way. your computer should be behind the kick panel...
