Building Up A FM146
smuj_2006
South Bend, Indiana
i have a fm146 out of a 88 ranger. i would like to rebuild it and somehow beef it up. does anyone know where i can get better bearings or gears?? thanks.
I'd like to have a 10,000 HP truck that gets 8 million MPG, but that's not going to happen either.
What MAKG is trying to say is with a FM146 that aint gonna happen, try to find a M50D instead to rebuild.....
does anyone have one that they can sell me??? i need soon. the fm146 is starting to make noises in first, second, and third. thanks.
Most likely your input shaft bearing....
Most likely starting with the input bearing. It's not very likely to be the only problem....
My mistake,
It is possible that it may be your input shaft bearing, but there are also many other possibilties to consider when a tranny makes said noise. An input bearing failure is a very common cause of the noise you are hearing. I you let out the clutch while stationary in neutral while the engine is running, can you hear it? Does it seem to get louder/progress with the engine rpm?
yes to both. does anyone know where i can find a m50d-r1??? all the junkyards around me dont have any.:dntknw:
