New parts!!
marcehboy
Maine
1990
Picked up these today. Found them in uncle henrys for $100 dollars new in the box.
New parts!!
New parts!!
thats a good deal i paid 200 for my body lift and cab bushings kit
I was about to pay 180 from duff but then came across an ad in the unclehenrys. I think i may need the shifter extension. Not sure which tranny i have though. It a 90 bronco II with 2.9 and five speed manuel transfer case.
what body lift is it when i did the 2 inch body lift on my bronco i ended up not needing a shifter extension
Should be a Mitsu tranny in your year BII.
it could be the Mazda M50D-R1 my bronco came from the factory with one
I dont know yet well se ill post up what happens. Right not im working on pulling the front clip off a 2wd ranger and getting the frame horns to for my bronco. I bought it wrecked for a hundred bucks and so far am in it around $450 with a 2 inch bl and new bushings, f150 leaf springs and 33s
thats good. how do the f150 springs fit and what yaer you get them from. i.m not sure 2.5in. springs went up to until they went to 3in. wide springs jw. thanks man
They are out of a mid 90s 2wd. the 2wd f150s were 2.5 and the 4x4 were 3 inches. I havent put them in yet and dont know how much lift its gunna give me. I am planning on cutting the spring eyes off the main leafs and use them under the bronco maine leaf just because its less work when the spring bolts are basically welded to the nut and bushing. I have two new center bolts and thats my plan. will keep posting with my progress
So no shifter extension needed correct?
My BII Has the M5OD, just depends on when it was built
