Biggest tire that could fit on stock suspension? 98 Rander 2wd
Cold Dark Shadow
Waseca MN
Im curious what the biggest tire i could get away with on stock suspension?
Its a 98 2wd standard cab step side.
Also want to level out the ride height (possibly lift it all the way around a couple inches) but cant find any like coil spacers or anything for it.
I have a 3in body lift on my 94. I am running 33x12.50r15 with swaybar removed. No other lift required. Just a little rubbing on radius arms on off camber tight turns.
Got any pics of the truck?
Seen the one with the 38s on it, looks sick
The picture is my avatar. I had to take the front swaybar off b/c the tires were rubbing on it. But i get alot better suspension flex now. I dont have any more pics on my computer besides the one I already have on here. I will try and post another.
heres a pic
3" body lift
33x12.50r15 Wild Country RVT on 15x8 rims with 4" backspacing
performance acc. 3in body lift off of ebay. $90. Took about 3 hours to install. Took 5 min to remove swaybar, almost a full day to change gears and add a l/s carrier.
What size is a 31" (xxx/xxr15) tire and would i still need a 3" bod lift to fit them?
