I'm getting my '86 ready for the road again and it developed a new problem. If i rev up the engine, usually around 2200rpm+ but sometimes off idle, it'll act like i just turn off the key then turn it back on quickly. I added a tach recently and when it cuts out the tach goes to 0 quickly then back up. The only code i have is a 33 for the EGR. I've had the truck since 2002 only put 10,000 miles on it and since then, not all at once, i replaced the TFI, all electrical stuff in the dist, cap with brass terminals, rotor, wires, plugs, switched coils trying to figure out a different problem, and the engine itself probably only has 20,000 miles or less. It obviously sounds like a loose connection somewhere with the spark, any ideas on what i should try? thanks
