question on tow hooks
You should already have Tow hooks? If not rangers have an opening to allow easy installation of them you should be able to just pick up a pair and bolt them on without any modification to my knowledge.
No spot for tow hooks on a 2wd, your best solution is to weld a from mounted hitch between your frame rails.
4wd rangers have a cross brace between the front two rails 2wds do not. you could find a wrecked 4wd and get it off that one
but if i do that idea from the explorer, will i be able to leave the valence the same?
no. Cause the explorer put it on the bottom of the frame rails. if you look you frame rails are a good distance from the bottom of the valance and there are no holes through the valance right there so, i guess you could do it but your hooks would be useless.
Front hitch it or custom crossmember it to mount the hooks to. As said in the above post, On a ranger, that wouldn't work because the valence is in the way, deeming those new towhooks useless. That is unless huge drop downs are used...
note: 95-01 Explorers/-05 sport and sport trac have (almost)the SAME frame as 4x4 Rangers. They are torsion bar regardless of drivetrain(2wd or 4wd). Same goes for the 2wd Trailhead/Edge/Sport Rangers. They've got the crossmember I've posted pics of in the past that the 98+ coilspring rangers lack. Front frames are totally different. Only thing similar is the holes the bumper mounts to and the width of the frame in front of the core support.
