- Feb 2, 2009
- Age
- 38
- Bemidji, MN
Ok guys so the power outlet outside my Apt. is currently about driving me to drink i have been having issues with it all last night and this morning. the main issue is that i am tripping the GFCI/GFI. its on a 120 volt plug in.
what i have running out of the box was a 2/10/50 amp battery charger/starter and a block heater on the GFs Dakota and that seemed to run just fine allnight with that and the charger was at the 10amp setting. i had been tripping it though when i attempted to plug in my F150s lower Rad hose heater so i chose to leave that off and then plug that in when she was at work and i had more power to use.
but now my current issue(no pun indended i think?) is that i have JUST the lower rad hose heater on it and its Tripping the switch almost under 10 secs in from the last reset. i have had it on there before and i dont recall if it tripped or not.
could there be a short somewhere in the wireing for the heater? if so is there a way to adress that or do i have to replace the unit as a whole? could it also be a worn out GFI? i dont know much about this stuff
thanks for any help you can offer guys
yeah the side mount would be wise.
