HID Install
sr975j
cincinnati
Just purchased a HID kits for my headlights and fog lights. Just wondering if anybody had some quick tips or tricks for this install. Or maybe if someone had a link or photos of their install. Im kinda lost when it comes to this electrical stuff, im more of a mechanical guy than an electrical guy.
Sam
make sure you get some HID pods and do it right........ just because you stick HID bulbs in your Halogen housings does not mean you have HID.
Yeah, because the proper housings make all the difference! The reduce glare to other drivers and are designed for the lights and send all of the light where you want it.
Note, You might run into people like me too if you put them in the stock housings, because they are really annoying and I can't see nuthin when people have them. My take on this is they want to annoy me so I'll annoy them Back with 860w of pure KC Power.
The projectors keep you legal as well
Finally, I found a legit/legal use for HIDs...
Seeing that I'm pretty anti-HIDs (BTDTGTTSWHAI - Been There, Done That, Got The T-Shirt, Wrote Home About It)....twice. I had a couple of HID take-offs (9006), and finally found a good use for one of them.
You may find this helpful, amusing, or even irritating :D
Check it out:
I just VHB taped the ballast to the top of the fuse box under the hood, and added alligator clips to the wire leads to clip to the battery whenever I need liht under the hood (but really, how often will that be? After all, it IS a Ranger, eh? :D )
I'm one of those persons... :D
You don't want to bother dipping your lights, then f%&k you I'll MAKE you dip! :thefinger:
**Flicks on 220w of insanely bright HID Hella madness**
Yea thats what I thought! :icon_rofl: lol
glad I am not the only one on the HID crusade.
We need an Illegal HID's Suck social group on here.
I have been ready a lot mag lately and almost ever truck i see with h.i.d headlights has stock or aftermarket halogens housing giving the illusion that they are legal and safe to run because they do..
Lol just to clarify... I don't have HID's in my headlight housings, I just have HID driving lights. I have silverstars in my normal housings.
I agree with everyone that you really do need projector housings if you're going to go HID. Its just plain inconsiderate to have HID's in your normal housings, and really if you're kinda a light junkie like me, you'll realize that the light output is really not any better than a good set of bright Halogen bulbs.
Think of it this way. Normal headlight housings aren't made to properly aim the light emitted from an HID bulb. The way light is emitted is different on an HID bulb than a halogen bulb.
This is a bit of an oversimplified example, but if you were to take a bare HID bulb and hold it up in front of your truck and turn it on, and then turn your normal halogen headlights on, which do you think would project light further, your headlights or the bare HID bulb? Your headlights with the halogen bulbs of course! Yes the HID bulbs are technically brighter than the Halogen bulbs, but the Halogens have a reflector which is optimized for the light they're emitting. The HID bulb doesn't (you're just holding it) Putting an HID bulb in a Halogen housing has a similar effect. You're not correctly focusing the light, and therefore you'll see the road no better than you would using a pair of Silverstar Ultras or Phillips xtreme bulbs.
Or is everyone just putting HID's in their car for the "cool" HID look?
I have not problems with HID as long as it is done right. find an HID projector to retrofit into you ride. I have seen Ranger Headlamp housings retrofitted with Lexus HID pods and then there are no glare issues. My problem with them is the glare, personally I want a set of LED headlamps because the consume about 1/10 of the energy and last 10x as long, and are vibration resistant where halogens are not.... and LED headlamps use a similar projector and cut off as HID so lenses should be easy to find.
Even if you did it the right way its still illegal to have them unless your truck came with them from the factory..
yeah ... you can apply the same logic to using halogens in a vehicle that came with incadecents......
this would have gone un noticed if all the guys with crappy HID bulbs in a halogen housing had done it right in the first place instead of arguing with everybody that told them to do it right...... see what happens ...... the 3% have to f*ck it up for the rest of us.
There is a misunderstanding about projectors being the solution to HID issues (glare, etc.) Yes, there is a "sharp cut off", but that's created by an internal metal plate in the housing. The reflector is still calibrated for a halogen bulb. Here's a little-observed point about HIDs (no matter the headlight type):
"But what about all the rave reviews you read in magazines and on Usenet about how marvelous HID headlamps are? Well, here's the double whammy of high levels of foreground light: When you can see every last pebble in the road, all the way across, it's very comforting. You don't have to strain to see what's immediately in front of the vehicle. And the most recent research seems to be suggesting that this, to an extent, improves driver performance at night, possibly because with the foreground adequately illuminated, we tend to trust our peripheral vision to handle the foreground, and keep focussed out in the distance where we should be looking. (See above comments regarding too-low levels of foreground light in many US headlamps...). BUT, foreground illumination is *only one* performance aspect of a headlamp, and it's very, very easy to judge a headlamp "good" because of very strong foreground light, when in fact the distance vision isn't so grand. In short (finally!) an HID headlamp has a strong tendency to create a false sense of security."
This applies, projector housings or otherwise. It has been compared to putting someone else's prescription glasses - you might be able to see, but not properly.
Yep! But try to tell people who are "victims" of the marketing efforts. Also, there is only 1 type of bulb base for an HID capsule. Anything made to retrofit (9006, 9005, H4, etc.) are all ba$tard productions, and are NOT authorized by the legitimate manufacturers of HID products such as Phillips and Hella (who do NOT make the HID "kits")
Yep, you got it! I too like the LED lighting technology. But LEDs are not quite "there" yet to use in certain applications, such as automotive.
There's lots of reading into this science of lighting, but sadly, people who are the most vehemently supportive of HID conversions tend to be aliterate, and won't read the facts. HID's "problems" are not implementation, they're conceptual. You can argue with physics, but you can't change it.
More reading:
http://www.danielsternlighting.com/tech/bulbs/Hid/HID.html
http://www.danielsternlighting.com/tech/bulbs/Hid/conversions/conversions.html
http://www.danielsternlighting.com/tech/bulbs/Hid/disadvantages/disadvantages.html
