Hey I'm doing a carbed 302 swap and Im going to try and use the stock in-tank fuel pump with a quick fuel return-type fuel pressure regulator (summit # QFT-30-899). Can I just get brass hose barbs, heat them up a bit, and push them in to the stock fuel hoses (the type with the super hard plastic tube on the inside and the rubber hose around that). or am i going to need to run AN line or something aftermarket?
