Ok, so let me start off by stating that i am a highly qualified technician and have done over 200 bolt, screw extractions in my line of work.....STORY......
I was about to mount my water pump on my 302 motor in my B2. And i decided to run the bolts through the old sticky bolt holes to kind of clean em out....
get to about the 5th hole and its sticking a bit...so i screw it in a bit tighter..(small amount...not much)...AND POP! its snaps off...about half an inch of bolt stuch in my block near the water inlet...DAMN!
So i pull the harmonic balancer, timing cover...and yup, nice and flush to the block its stuck good...
SO I START AN EXTRACTION...NO SWEAT!
Drilled perfectly, extractors in a fair distance...nothing...tighter...nothing...tighter with the assistance of visegrips....BENT! OH SH@T! NOT GOOD
so what do it do
I go buy a new extractor kit....Drill it out all the way through...spray wd40 in behind the bolt...let it sit over night...and use a larger extractor...NOTHING...so i try to turn it harder....and HARDER...and then SNAP!!!!!!!!!!!!!!!!!!!!!!!!
OH SHIT....IM SCREWED
So ive got a bolt drilled out to max, with a hardened extractor stuck in the top right side of my block......
ANYONE GOT AN OPINION....Ive already tried heating it...NOTHING....tried breaking it with a Hard Chizel...NOTHING...
IVE GOTTA GET THAT OUT BEFORE I CAN GO ANY FURTHER...
and i have no problem drilling it larger and retapping it...and it doesnt go through to a water jacket line...its just a hole...so im basically up for anything...
HOW DO I BREAK THE EXTRACTOR? WITH OUT MESSING UP MY BLOCK MUCH FURTHER?
