- Mar 12, 2009
- new market
locker in the rear is good. locker in the front bad. but like said above rear tires will wear a bit more than normal but hey if you want a locker bad enough its a small price to pay for good traction like i said though you will have to change your drive style a bit and get used to driving with one and like said they are very noisey alot of clanking and banging when they unlock and lock a good ls in the front or a selectable locker for the front would be good. a locker for the front would still be bad even with manual hubs even though no power is going to the front and the hubs are unlocked the locker wont need power it will still be locked cause the tires are still moving and it would still able to unlock and throw the front end around and could cause you to have an accident. now some people say to lock on hub and leave the other unlocked this is very bad it can wear out the hub you have locked and if you forget and you put it in 4hi it could messin up the front end of your truck
