- Nov 30, 2001
- Gnaw Bone, Indiana
id rather have a non-turbo diesel than a turbo equipped one though...the non-turbo oliver has a broder rpm range (remember, with a turbo the rpms need to be kept within a certian range or it falls on its face) and has been much better on fuel useage.
I don't know anything about Oliver tractors, but having a truck with a turbo is much better than having a truck without a turbo. More power, more torque, better mileage, quieter and the engine runs much cooler EGTs under normal use and lasts longer. A modern turbo lasts as long as the engine pretty much. I have installed 2 Banks turbo kits because though a nastilly-asspirated diesel feels okay just driving around, it's not good with a trailer. And the EGTs go through the roof. I wouldn't turn up the pump and work it very hard. If you see black smoke, it's really hot. My 6.2 without a turbo would run 800F just going 60mph down the road empty. With the turbo, same speed and therefore making the same speed and making the same power, it's running 400F and very quietly. When my motor is at 800F you are pulling a decent load up a grade and making a hell of a lot more power than the non-turbo truck is capable of--and still have lots of reserve power. That's a major advantage
The DB2 pump in the 6.9/7.3 is capable of putting out enough fuel for 250hp and 450ft#--engine displacement doesn't matter with the turbo.
