Tow Hook Idea
wizkid00104
West Newton/Penn Hills, PA
My buddy gave me a tow hook off he sheared the bolts off of from his 2004 F-150. It is a huge tow hook. I was thinking about bolting it to my rear bumper hole. It looks cool but I dont know how well it would work. Any ideas on other ways to mount it to the back?
the step bumper is much too weak to be used for a recovery hook mount. the hook needs to be attached directly to the frame in order to be usable.
Well, I don't know. Most people put on a tow hook and it's held the the bottom flange of the end of the frame with 2 bolts. The step bumper is bolted to the web of the frame with 4-6 bolts. A towing step bumper has the center section reinforced between the frame members. It's really not a problem. Lots of people use a 3/4" clevis pinned through that hole and it is better than a tow hook in my opinion. Just make sure it's a good bumper well bolted and reinforced.
I don't like either method. I hate tow hooks on the bottom web. They bend the frame in many cases. The bumper is better as it's pulling on the webs with more bolts. The best for the rear is a reciever or custom bumper.
if your bending the stubs of the frame with them then imagine what the same amount of force would do when applied to the center of a bumper. id rather bend the stubs of my frame a little than the middle of my bumper a lot.
ill agree that a reciever hitch is the best option for rear recovery though....mine has come in VERY handy.
I don't have to imagine anything. I've seen a lot of clevis's in the ball hole and never seen a bumper fail. I've seen crappy bumper roll forward. A good bumper has a 1/4" plate between the rails. My B2 bumper does.
your saying the stock step bumper is stronger than a hook bolted directly to the frame rails...
give me some of what youre smoking.
ive seen factory step bumpers tweaked all out of shape just from towing with them...much less the jolting forces experienced during a recovery effort.
in fact my step bumper was bent just from a taught tow chain (attached to my receiver) rubbing against it.
