- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Tire Size
- 35x12.50R15
so, are they pullies welded in place and don't move, the cable only slides on them?
Notice the pulley's axle pin and clip sitting on top of the tube there. That's what they rotate on
The cable is simply wrapped around the swaybar bolt on the axle, and secured with two cable clamps.
I am missing the point here. What is the purpose of the straps and doesn't it limit flex ????
When climbing a steep hill or any obstacle that points the hood of the truck upward (especially on a short-wheelbase rig like a BII, or jeep), weight transfer carries much of the vehicle's weight onto the rear (or downhill) axle. This causes the front suspension to unload (extend out), further raising the hood and throwing even more weight onto the rear. The better you can keep the front axle down (and keeping more weight on it), the better your stability and overall traction will be.
In the case of a TTB with the notoriously crappy steering you get with a mis-matched pitman arm, the suspension's unloading becomes compounded by the tires toe-ing in at the same time. A limit strap or cable would certainly help some with this as well.
Flex is not limited in any way. As one side moves up, the other side is allowed to move down.
