2wd tranny 4x4 t-case???
QuakerShaker4242
Avon, IN
hey guys im doing a 4x4 conversion sas and i was just wondering... would i need to get an entire new transmission... or just a 4x4 transfercase???
You could run a divorced transfer case, but that would require a lot of modifications. Like metal said, you would be far better off just getting a 4x4 transmission.
the output shaft on the 2wd tranny wont fit the transfercase. you need a new tranny.
so just to reassure myself... is it any 4x4 transmission or a certain year?
assuming you have a 2wd ranger..
yea... it even says on my public profile
if its a manual you will want a 4x4 tranny that was behind the same engine as yours (2.3L, 3.0L, or 4.0L) as the bellhousing is different for each engine.
right. i gotcha. i have a 4.0L automatic. so basically i need a tranny from a 4x4 4.0L automatic... correct?
