- Aug 30, 2007
- Age
- 38
- Cass Co, Missouri
So I got to thinking...
My truck needs longer driveshafts, and there is a longer factory shaft, but will it work?
I looked up the wheelbases and there is practically a foot difference. Assuming there is another foot on the 98+ driveshaft, it would most likely have to be cut down to fit my truck, but that would cut cost of having a completely new shaft made.
I was also thinking, that aluminum wouldn't be such a good idea for my means of use. Is there a steel one available?
I don't need high angle joints or anything in the rear, but I am approximating that I'll need about another 5" of length. But, would there be enough travel in a OEM shaft's slip joint?
Good idea? Worth a try? Who knows, What do you think?
