ig109
- Sep 29, 2009
I have a 98 Ranger 2.5 5 speed that i just replaced timing belt, plugs, wires, tps, and thermostat.. also repaired the vacuum lines that were busted, replaced fuel filter, cleaned the KandN, cleaned and sandblasted the intake while it was off.cleaned the trottle body to releave the junk buildup.. and also cleaned the egr valve and iac.. All are functioning to the best of my knowledge.. the timing was right when i checked it twice after doing the belt.. Truck runs excelent when you drive down the road.. however, when it is idling in the driveway and you try to rev it up it wants to miss and or hesitate and carry on.. Sometimes it will pop into the intake tube, like a backfire.. No Codes, only thing weird on the scan tool is the fact that with the key on and no throttle pressure it shows 17%... i unplugged the TPs with it running one day and it acted the same as this issue only worse.. so i bought a new TPS and that didnt do anything.. HELP PLEASE!!!!!!!
